Uno Член клуба
Возраст: 53 Знак зодиака:  Зарегистрирован: 16.02.2009 Сообщения: 13802 Откуда: Киев Оболонь
granadam50 Италолюбитель
Возраст: 45 Знак зодиака:  Зарегистрирован: 08.11.2012 Сообщения: 72 Откуда: Одесса
Авто: FIAT Regata 100S
Добавлено: Вт Ноя 27, 2012 21:55 Заголовок сообщения: |
лан фпопу францию..... перейдем в Британию
ENGINE
Transverse, mid, rear-wheel drive
Head/ block al. alloy/al alloy. 4 cylinders in line.
Bore 95.3mm, stroke 76.2mm,
capacity 2174cc.
Valve gear 2ohc. 4 valves per cylinder.
Compression ratio 80 to 1.
Electronic breakerless ignition.
Twin Dellorto DHLA 45 carburetors
Garrett T3 turbocharger.
boost pressure 9.5psi (0.67bar).
Max power 215bhp (PS-DIN) (160kW ISO) at 6000rpm.
Max torque 2201b ft (298 Nm) at 4250rpm.
TRANSMISSION
5-speed manual
Gear Ratio
Top 0.82
4th 1.03
3rd 1.38
2nd 2.05
1st 3.36
Final drive ratio 3.88:1.
Transaxle: Renault UN1-16 all - Syncromesh
SUSPENSION
Front, independent, double wishbone. co-axial coil springs, telescopic dampers, and-roll bar. Rear, independent, upper and lower transverse link with radius arms, coil springs, telescopic dampers, anti-roll bar.
STEERING
Rack and pinion.
Steering wheel diameter l4ins,
2.9 turns lock to lock.
BRAKES
Front l0.1ins(258mm) dia ventilated discs.
Rear l0.8ins (275.9mm) dia discs.
Vacuum servo.
WHEELS
Al alloy,7ins rims front. 8ins rear.
Goodyear Eagle NCT tyres
size 195/60VR15 F,
235/60VR15 R.
DIMENSIONS
Length: 4330 mm
Width: 1860 mm
Height: 1150 mm
PERFORMANCE
Maximum Speed: 153.5 mph (247 kpm)
Acceleration: 0 - 60 mph, 5.4 Seconds
Standing mile: 13.7secs, 103mph
standing KM: 25.0secs, 129mph
FUEL CONSUMPTION
Overall mpg: 19.6 (14.4 litres/100km)
Fuel tank: 18.0 Imp galls (82 litres)
Mileage recorder 4 per cent long
CLUTCH
Pedal 15lb; Travel: 6.O ins
Single Dry Plate 235 mm diameter, diaphragm spring cover assembly, hydraulic operation
WEIGHT
kerb 3052lb/1386kg
distribution % F/R 51/49
Test 3434lb/l559kg
Max payload 501lb/227kg
COST
LOTUS ESPRIT TURBO NEW IN 1988 - £29.950.00
вопросы еще есть?)))
Последний раз редактировалось: granadam50 (Вт Ноя 27, 2012 21:57), всего редактировалось 3 раз(а) |
Возраст: 45 Знак зодиака:  Зарегистрирован: 05.11.2010 Сообщения: 25283 Откуда: Одеса
Добавлено: Вт Ноя 27, 2012 22:01 Заголовок сообщения: |
и снова: 0.67 бар...сосиська...дельта ЕЦВ в стоке 600 коняк
Position Rear, Longitudinal
Cylinders 4 in line
Diameter/Stroke 88.5 x 71.5 mm
Total Capacity 1759 cm3
Cyl-Head Type TRIFLUX twin flow
Valves 2 Inlet/2 Exhaust per cylinder, DOHC
Compression Ratio 7.5:1
Power 600 CV at 8000 rpm
Torque 55 kgm at 5000 rpm (это 550 N*m, если чо)
Boosting Two K.K.K. K26 Turbochargers and two air-air intercoolers (one for each turbocharger)
Injection/Ignition WEBER/MAGNETI MARELLI IA.W. integrated ignition and injection with electronic boost control
Lubrification Oil dry sump with engine driven oil-pump (send & return) to separate 7 Litre separator tank. Oil-cooler radiator
так шо не всегда большая пиписька - залог успеха на гонках...
но посоны, мы отвлеклись от темы, главный вопрос был: зачем мотору 138С3.048 улитка? _________________ СТО [:ІЖАК] - діагностика, ремонт і кава ^-^
Uno Член клуба
Добавлено: Вт Ноя 27, 2012 22:04 Заголовок сообщения: |
granadam50
спор о чем? о том что в карб только специально сконструированый можно дунуть, а не в первый попавшийся с волги... и сам мотор тоже должен быть изначально сконструирован под наддув иначе если дунуть в стоковый атмосферник то загнется он быстрее чем его собирали как ты думаеш какого на абсолютно одинаковом блоке с 1,3 стоят разные коленвалы, поршня, головы со всеми потрохами, маслонасосы и еще куча"мелочей"? только по тому что один турбо а второй атмосферник  _________________ FuckFuelEconomy-Turbo Power I’m Lovin' it
добло |
Добавлено: Вт Ноя 27, 2012 22:09 Заголовок сообщения: |
Renault 5 Alpine участвовала в составе Group 2 на ралли Монте-Карло и заняла второе и первое место в 1977 году. В 1978 году Renault 5 Alpine пришёл вторым и третьим в общем зачёте, несмотря на ощутимую конкуренцию со стороны Fiat и Lancia.
В 1978 году введена Group 4 (позже Group B). Она имела в своём составе Renault 5 Turbo с продольно расположенным двигателем и задним приводом, что делало его схожим с обычной дорожной версией. Он имел форму и общий вид 5 модели с немного изменёнными дверными ручками. Управляемый Жаном Ранотти (Jean Ragnotti), этот автомобиль выиграл Монте-Карло в 1981 году. 2WD R5 турбо пришлось вскоре столкнуться с конкуренцией в виде новых 4WD автомобилей.
Uno Член клуба
Добавлено: Вт Ноя 27, 2012 22:10 Заголовок сообщения: |
гыыыыыы.... так о группе б я и говорю мож погуглиш шо такое лянча эс4 и чего она добивалась я те сцылко не зря кинул просвещайся  _________________ FuckFuelEconomy-Turbo Power I’m Lovin' it
Последний раз редактировалось: Uno (Вт Ноя 27, 2012 22:28), всего редактировалось 1 раз |
Добавлено: Вт Ноя 27, 2012 22:19 Заголовок сообщения: |
| FIATuno писал(а): | гыыыыыы.... так о группе б я и говорю мож погуглиш шо такое лянча эс4 и чего она добивалась я те сцылко не зря кинул просвещайся  |
так я чОтко написал что рено 2вд а лянча 4вд))) я те напомню что такое ауди кватра или форд Рс200 а форд со своей сьерой Косворт РС500 ехал не хуже лянчи
компрессор карбюратор Корд-812))) передний привод)) |
Добавлено: Вт Ноя 27, 2012 22:22 Заголовок сообщения: |
это всё лирика и флуд.
какое отношение фордовские карбы имеют до турбины на регатовской разжатой полторушке?????
господа флудерасты, нарываемся на турецкую сухую парную? это ж очевидно! _________________ СТО [:ІЖАК] - діагностика, ремонт і кава ^-^
Последний раз редактировалось: CreAtoR (Вт Ноя 27, 2012 22:29), всего редактировалось 1 раз |
Добавлено: Вт Ноя 27, 2012 22:29 Заголовок сообщения: |
и снова выбрасываем грибы в окно)))
1957 FORD THUNDERBIRD
V8 5.1л 300лс
лан на этом я успокоюсь) я свое мнение высказал)) в карбы дуют и это факт! |
Добавлено: Вт Ноя 27, 2012 22:30 Заголовок сообщения: |
| CreAtoR писал(а): | это всё лирика и флуд.
господа флудерасты, нарываемся на турецкую сухую парную? это ж очевидно! |
дуют в карбы и признайте это  |
та...видел такую возле ситицентра... _________________ СТО [:ІЖАК] - діагностика, ремонт і кава ^-^
Добавлено: Вт Ноя 27, 2012 22:32 Заголовок сообщения: |
granadam50
некоторые и в кожаные дудки дуют, но это не делает их лучше нас с вами
пёрнуть в карб - не значит сделать мотор турбовым... _________________ СТО [:ІЖАК] - діагностика, ремонт і кава ^-^
Do_Sancho Италоманьячище
Возраст: 36 Знак зодиака:  Зарегистрирован: 08.06.2009 Сообщения: 2185 Откуда: Одесса
Добавлено: Вт Ноя 27, 2012 22:33 Заголовок сообщения: |
| granadam50 писал(а): | | Цитата: | а ваши псевдотурбокарбовые рено - че-пу-ха!
_________________ |
Лянча курит в сторонке в бой идут пацаны с большими пиписками))))) |
Если лянча курит то эта большая пиписка сасёд....
толку с неё???
расход в цистерну ????
Что на ней делать в городе???
что на ней делать "а вдруг снег???
что на а вдруг пыль...песок???
на ней вообще комфортно???
а там в салоне сидеть токо в шлеме???
и при этом кошелёк нада такой чтобы на чемодан был похож...
Если человек который ездит на фиате показывает подкапотку мускул кара чуть ли не слюни пуская то на мой взгляд это комплекс...
И что интересно те двигателя выигрывали???
по-моему я знаю-номинацию в самый большой тупорылый двигатель,.. _________________ ***In SNAIL we Trust***
Fiat Regata 105 TC Full MPI>Dedra Integrale GT28RS 380 hp 1.6 bar ; AR 155 Q4 ; Alfa romeo 166 3.0 V6 sporttronic ; Subaru Forester S-edition 260 h.p. |
Uno Член клуба
Добавлено: Вт Ноя 27, 2012 22:34 Заголовок сообщения: |
ну в парилку неза что посколько человек спорит без сквернословия и оскорблений хоть не сильно знаком с предметом. отстаивает свою точку зрения, а мы вправе с ней не согласиться или опровергнуть может чего полезного для себя почерпнет... мож и мы чего нового увидим... _________________ FuckFuelEconomy-Turbo Power I’m Lovin' it
Последний раз редактировалось: Uno (Вт Ноя 27, 2012 22:39), всего редактировалось 1 раз |
