Турбина на Regata 138C3 1.5
СообщениеДобавлено: Вт Ноя 27, 2012 21:55    Заголовок сообщения: Ответить с цитатой
ага... и чмокала у лянчи Laughing где результаты рено в ралли?
почитай вот эту тему... мож узнаеш чего нового.... http://fiat-club.org.ua/forum/viewtopic.php?t=8866
granadam50
Авто: FIAT Regata 100S
лан фпопу францию..... Laughing перейдем в Британию Laughing
ENGINE
Transverse, mid, rear-wheel drive
Head/ block al. alloy/al alloy. 4 cylinders in line.
Bore 95.3mm, stroke 76.2mm,
capacity 2174cc.
Valve gear 2ohc. 4 valves per cylinder.
Compression ratio 80 to 1.
Electronic breakerless ignition.
Twin Dellorto DHLA 45 carburetors
Garrett T3 turbocharger.
boost pressure 9.5psi (0.67bar).
Max power 215bhp (PS-DIN) (160kW ISO) at 6000rpm.
Max torque 2201b ft (298 Nm) at 4250rpm.
TRANSMISSION
5-speed manual
Gear Ratio
Top 0.82
4th 1.03
3rd 1.38
2nd 2.05
1st 3.36
Final drive ratio 3.88:1.
Transaxle: Renault UN1-16 all - Syncromesh
SUSPENSION
Front, independent, double wishbone. co-axial coil springs, telescopic dampers, and-roll bar. Rear, independent, upper and lower transverse link with radius arms, coil springs, telescopic dampers, anti-roll bar.
STEERING
Rack and pinion.
Steering wheel diameter l4ins,
2.9 turns lock to lock.
BRAKES
Front l0.1ins(258mm) dia ventilated discs.
Rear l0.8ins (275.9mm) dia discs.
Vacuum servo.
WHEELS
Al alloy,7ins rims front. 8ins rear.
Goodyear Eagle NCT tyres
size 195/60VR15 F,
235/60VR15 R.
DIMENSIONS
Length: 4330 mm
Width: 1860 mm
Height: 1150 mm
PERFORMANCE
Maximum Speed: 153.5 mph (247 kpm)
Acceleration: 0 - 60 mph, 5.4 Seconds
Standing mile: 13.7secs, 103mph
standing KM: 25.0secs, 129mph
FUEL CONSUMPTION
Overall mpg: 19.6 (14.4 litres/100km)
Fuel tank: 18.0 Imp galls (82 litres)
Mileage recorder 4 per cent long
CLUTCH
Pedal 15lb; Travel: 6.O ins
Single Dry Plate 235 mm diameter, diaphragm spring cover assembly, hydraulic operation
WEIGHT
kerb 3052lb/1386kg
distribution % F/R 51/49
Test 3434lb/l559kg
Max payload 501lb/227kg
COST
LOTUS ESPRIT TURBO NEW IN 1988 - £29.950.00
вопросы еще есть?))) Laughing
Последний раз редактировалось: granadam50 (Вт Ноя 27, 2012 21:57), всего редактировалось 3 раз(а)
СообщениеДобавлено: Вт Ноя 27, 2012 22:01    Заголовок сообщения: Ответить с цитатой
и снова: 0.67 бар...сосиська...дельта ЕЦВ в стоке 600 коняк
Position Rear, Longitudinal
Cylinders 4 in line
Diameter/Stroke 88.5 x 71.5 mm
Total Capacity 1759 cm3
Cyl-Head Type TRIFLUX twin flow
Valves 2 Inlet/2 Exhaust per cylinder, DOHC
Compression Ratio 7.5:1
Power 600 CV at 8000 rpm
Torque 55 kgm at 5000 rpm (это 550 N*m, если чо)
Boosting Two K.K.K. K26 Turbochargers and two air-air intercoolers (one for each turbocharger)
Injection/Ignition WEBER/MAGNETI MARELLI IA.W. integrated ignition and injection with electronic boost control
Lubrification Oil dry sump with engine driven oil-pump (send & return) to separate 7 Litre separator tank. Oil-cooler radiator
так шо не всегда большая пиписька - залог успеха на гонках...
но посоны, мы отвлеклись от темы, главный вопрос был: зачем мотору 138С3.048 улитка?
СообщениеДобавлено: Вт Ноя 27, 2012 22:04    Заголовок сообщения: Ответить с цитатой
granadam50
спор о чем? о том что в карб только специально сконструированый можно дунуть, а не в первый попавшийся с волги... и сам мотор тоже должен быть изначально сконструирован под наддув иначе если дунуть в стоковый атмосферник то загнется он быстрее чем его собирали Laughing как ты думаеш какого на абсолютно одинаковом блоке с 1,3 стоят разные коленвалы, поршня, головы со всеми потрохами, маслонасосы и еще куча"мелочей"? только по тому что один турбо а второй атмосферник Wink
granadam50
СообщениеДобавлено: Вт Ноя 27, 2012 22:05    Заголовок сообщения: Ответить с цитатой
пепец.........
http://www.youtube.com/watch?v=VRHaEEu9adk
Laughing
знаешь что такое группа Б ?)))) Laughing
О_о еще нашел))) бмв-2002 турбо
и фотка карбов лотоса)))
Laughing
granadam50
СообщениеДобавлено: Вт Ноя 27, 2012 22:09    Заголовок сообщения: Ответить с цитатой
Renault 5 Alpine участвовала в составе Group 2 на ралли Монте-Карло и заняла второе и первое место в 1977 году. В 1978 году Renault 5 Alpine пришёл вторым и третьим в общем зачёте, несмотря на ощутимую конкуренцию со стороны Fiat и Lancia.
В 1978 году введена Group 4 (позже Group B). Она имела в своём составе Renault 5 Turbo с продольно расположенным двигателем и задним приводом, что делало его схожим с обычной дорожной версией. Он имел форму и общий вид 5 модели с немного изменёнными дверными ручками. Управляемый Жаном Ранотти (Jean Ragnotti), этот автомобиль выиграл Монте-Карло в 1981 году. 2WD R5 турбо пришлось вскоре столкнуться с конкуренцией в виде новых 4WD автомобилей.
Wink
СообщениеДобавлено: Вт Ноя 27, 2012 22:10    Заголовок сообщения: Ответить с цитатой
гыыыыыы.... так о группе б я и говорю Laughing мож погуглиш шо такое лянча эс4 и чего она добивалась Laughing я те сцылко не зря кинул Wink просвещайся Laughing
Последний раз редактировалось: Uno (Вт Ноя 27, 2012 22:28), всего редактировалось 1 раз
granadam50
СообщениеДобавлено: Вт Ноя 27, 2012 22:19    Заголовок сообщения: Ответить с цитатой
Laughing так я чОтко написал что рено 2вд а лянча 4вд))) я те напомню что такое ауди кватра Laughing или форд Рс200 Laughing а форд со своей сьерой Косворт РС500 ехал не хуже лянчи Very Happy
компрессор карбюратор Very Happy Корд-812))) передний привод))
СообщениеДобавлено: Вт Ноя 27, 2012 22:22    Заголовок сообщения: Ответить с цитатой
это всё лирика и флуд.
какое отношение фордовские карбы имеют до турбины на регатовской разжатой полторушке?????
господа флудерасты, нарываемся на турецкую сухую парную? это ж очевидно!
Последний раз редактировалось: CreAtoR (Вт Ноя 27, 2012 22:29), всего редактировалось 1 раз
granadam50
СообщениеДобавлено: Вт Ноя 27, 2012 22:29    Заголовок сообщения: Ответить с цитатой
и снова выбрасываем грибы в окно))) Laughing
1957 FORD THUNDERBIRD
V8 5.1л 300лс
лан на этом я успокоюсь) Very Happy я свое мнение высказал)) в карбы дуют и это факт!
granadam50
СообщениеДобавлено: Вт Ноя 27, 2012 22:30    Заголовок сообщения: Ответить с цитатой
дуют в карбы и признайте это Wink
та...видел такую возле ситицентра...
СообщениеДобавлено: Вт Ноя 27, 2012 22:32    Заголовок сообщения: Ответить с цитатой
granadam50
некоторые и в кожаные дудки дуют, но это не делает их лучше нас с вами Smile
пёрнуть в карб - не значит сделать мотор турбовым...
Do_Sancho
СообщениеДобавлено: Вт Ноя 27, 2012 22:33    Заголовок сообщения: Ответить с цитатой
granadam50 писал(а):
а ваши псевдотурбокарбовые рено - че-пу-ха!
Лянча курит в сторонке Laughing в бой идут пацаны с большими пиписками)))))
Если лянча курит то эта большая пиписка сасёд....
толку с неё???
расход в цистерну ????
Что на ней делать в городе???
что на ней делать "а вдруг снег???
что на а вдруг пыль...песок???
на ней вообще комфортно???
а там в салоне сидеть токо в шлеме???
и при этом кошелёк нада такой чтобы на чемодан был похож...
Если человек который ездит на фиате показывает подкапотку мускул кара чуть ли не слюни пуская то на мой взгляд это комплекс...
И что интересно те двигателя выигрывали???
по-моему я знаю-номинацию в самый большой тупорылый двигатель,..
***In SNAIL we Trust***
СообщениеДобавлено: Вт Ноя 27, 2012 22:34    Заголовок сообщения: Ответить с цитатой
ну в парилку неза что посколько человек спорит без сквернословия и оскорблений хоть не сильно знаком с предметом. отстаивает свою точку зрения, а мы вправе с ней не согласиться или опровергнуть Wink может чего полезного для себя почерпнет... мож и мы чего нового увидим...
Последний раз редактировалось: Uno (Вт Ноя 27, 2012 22:39), всего редактировалось 1 раз
Страница 4 из 6
