Добавлено: Ср Мар 18, 2015 16:57 Заголовок сообщения:
Цікаво дізнатися вартість корпуса для сабіка, ЗЯ, максимально малого об'єму. Саб ось такий: Monacor Carpower BlackBass-10
Параметри з сайту виробника:
BLACKBASS - this does not merely describe the appearance of these new top-class subwoofers from CARPOWER. They provide a powerful and at the same time a very clear bass reproduction of low fundamental resonance up to the threshold of pain. In this price class, both the mechanical stability and the sound set standards.
High-power subwoofer, 2 x 250WMAX, 2 x 4Ω
The 25cm version of this bass speaker with carbon fibre cone also provides a powerful reproduction. High power capability, long excursion, perfect stability, and high quality materials applied at this speaker like special rubber surround and the extended CARPOWER full air circuit cooling of the drive system with rear ventilated spider, drilled pole core AND air gap provide an amazingly clear sound at every application. This 2 x 4Ω bass speaker with dual voice coil provides a bass reproduction of low fundamental resonance in bass-reflex cabinets of about 45 litres, real enjoyment also possible with closed cabinets, approx. 25 litres only.
Impedance (Z) 2 x 4Ω
Resonant frequency (fs) 32Hz
Max. frequency range f3-300Hz
Music power 2 x 250WMAX
Power rating (P) 2 x 175WRMS
SPL (1W/1m) 86dB
Suspension compl. (Cms) 0.19mm/N
Moving mass (Mms) 130g
Mech. Q factor (Qms) 7.2
Electr. Q factor (Qes) 0.46
Total Q factor (Qts) 0.43
Equivalent volume (Vas) 30 l
DC resistance (Re) 2 x 3.6/1 x 1.8Ω
Force factor (BxL) 10.5Tm
Voice coil induct. (Le) 2 x 0.7mH
Voice coil diameter 50mm
Voice coil former aluminium
Linear excursion (XMAX) ±15mm
Eff. cone area (Sd) 325cm2
Magnet weight 90oz.
Weight 5kg
Возраст: 38 Знак зодиака: Зарегистрирован: 12.11.2009 Сообщения: 336 Откуда: Киев
Авто: Fiat Tipo 1.4 -> Alfa Romeo 156 1.8TS -> Honda Civic VI Coupe 1.6 Turbo -> Honda Accord 5 Coupe 2.2
Добавлено: Ср Мар 18, 2015 17:00 Заголовок сообщения:
если кубик - то 800грн с двойной передней стенкой, из фанеры 18мм, перетянут карпетом и с терминалом для подключения.
Если со скошенной задней стенкой, то 1000 _________________ Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
(о44) 384-22-82, (о63) 384-10-10
Добавлено: Ср Мар 18, 2015 17:33 Заголовок сообщения:
Краще, звісно, зі скошеною стінкою. А який розрахунковий об'єм буде? Фізичні розміри? _________________ Йожег сцуко лічнасть!
Добавлено: Чт Мар 19, 2015 02:07 Заголовок сообщения:
завтра посчитаю, а то это надо старый комп запускать)) только там програмулина идет. _________________ Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
Добавлено: Чт Мар 19, 2015 13:52 Заголовок сообщения:
сори, то фазик был, закрытый хочет 20,6 л жэто к примеру 30х30х30(15)см _________________ Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
Саш, привет.
Шумка и вибра, случайно, по хорошей цене не найдется?
Привет. Ну тут б/ушки не бывает))) так что цена стандартная и клубням скидка. Посмотри "Стандарт" - цена/качество. _________________ Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
Старая сигналка накрылась не так давно......а на полке уже почти год пылится Scher-Khan Magicar 7 . По чем нинче установка сигнализации??? _________________ Разборка вэнов Фиат Улис Скудо, Пежо 806 Эксперт Ситроэн Джампи Эвазион. 096 303 77 45 093 460 41 44 Александр. Ремонт КПП и АКПП. СТО. Ремот ходовой,двигателей.
гривен 500, но мы пока не занимаемся сигналками, разве что поучится на тебе могу за пиво)), но пока до конца недели работа есть _________________ Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
Привет в кратце! У меня в Тмпре SW в торпеде стоят какието пионерчики, по звуку меня вполне! В штатных сзади стоял какойто хлам допотопный маде ин джермани ели прочитал выгоревшие буквы)! Заменил на двухполосные китайские динамы (подогнали на шару)мафон Pioneer 3050ub как он валит меня НУ ОЧЕНЬ устраивает до него был kenwood kdc w312 - отличный аппарат но без юсб! так мне бы вот совет- какие в штатнеые 13 кинуть динамы до 1500 грн чтобы качали норм басок или проще вырезать с зади в бочинах подиумы и кинуть 16,5 круглые динамы или овалы! (В добле у меня стоит панас магнитола а динамы туда взял Pioneer Ts-a170ci так они так валять качественно и чисто и бас просто ,,,здец что мне и саба ненадо! _________________
Не совсем понял что у тебя там где))) знаю по типку, что в торпеде 10ки, в дверях вроде 13шки, но если не ошибаюсь, то 16 туда влезут с небольшими доработками. В общем я б посоветовал кинуть в двери нормальные динамики и обработать все правильно, ну если есть возможность, то овалы в заднюю полку лишними не будут, а про торпедо забыть. А лучше всего подьехать ко мне "на березки", думаю почти все форумчане знают где это постоять, обкурить и посмотреть что там и как лучше. Вот _________________ Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
В темпре универсале в дверях нет дюрок! Есть в торпеде 10-ки там у меня пионеры и штатные места над крыльями из нутри 13-ки там корочее типо как в жигулях 4-ке если видел! под самыми боковыми задними стеклами! Полки у меня небыло( гдето выброшена прошлыми владельцами!) _________________
Ну не знаю, надо смотреть что там можно сделать. В идеале заезжай - разберемся, не, так думаю надо 13е компоненты брать, например hertz dsk130, от магнитолы будет огонь играть. _________________ Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
Привет.
Хочу поменять на линии голову и динамики.
Посоветуйте, голову процесорный alpine или clarion акустику hertz, бюджет +- 5000/6000 грн
Привет. Из процессорных по сути есть только одна голова http://khz.com.ua/products/clarion-cz703e
Если бюджет ограничен такой суммой, то тут надо отказаться от процессоров, толку все равно не будет, взять что попроще, да чтоб чего то добиться в комплексе _________________ Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
Вы не можете начинать темы Вы не можете отвечать на сообщения Вы не можете редактировать свои сообщения Вы не можете удалять свои сообщения Вы не можете голосовать в опросах Вы не можете присоединять файлы в этом форуме Вы не можете скачивать файлы в этом форуме
