Andrii Италофан
Возраст: 49 Знак зодиака:  Зарегистрирован: 03.05.2009 Сообщения: 279 Откуда: Киев
Авто: Fiat Grande Punto '06
Добавлено: Пн Апр 29, 2013 15:13 Заголовок сообщения: |
Self-learning procedure
After the control unit or one of the actuators (excluding the recirculation one) has been replaced, it is necessary to proceed as follows.
CONTROL UNIT REPLACEMENT
Some of the CAN nodes, including the climate control system control unit, are programmed with default settings that the customer will find when they purchase the vehicle. If the control unit is being replaced, the Parts Dept. will send a "virgin" component: once fitted, the data memorized by the Body Computer must be transferred to it by carrying out the PROXI ALIGNMENT procedure using the Examiner.
ACTUATOR REPLACEMENT
The self-learning procedure must be carried out using the Examiner (automatic procedure) or following the instructions given below (manual procedure).
1. Carry out the key on and within 40 seconds press the AUTO and MONO buttons simultaneously and keep them pressed.
2. After a few seconds a figure will appear in the left temperature display and decrease (from 05 to 00) (count down) indicating the remaining time before the start of the procedure (keep the AUTO and MONO BUTTONS PRESSED).
3. When the left temperature reaches the value (00), releasing the auto and mono buttons will initiate the procedure lasting about 40 seconds.
4. Entering into local fault diagnosis, at the end of the procedure, the right temperature may display the following values:
00 SELF-LEARNING taken place with OK outcome
01 and flashing SELF-LEARNING taken place with NOK outcome
02 SELF-LEARNING in progress
03 and flashing SELF-LEARNING not completed
The self-learning procedure does not take place if the AUTO and MONO buttons are released before the left temperature reaches zero.
The control unit makes the left temperature flash if the self-learning has not been carried out or if the result is not positive.
FORCED EXIT FROM THE PROCEDURE
When in progress, the self-learning procedure may be:
1. Aborted: when the user deactivates the key on signal.
In this case the system exits the procedure in a controlled manner without changing the state of the self-learning information memorized previously in the EEPROM and memorizes the data relating to the "self-learning not carried out" state.
2. Interrupted: when the +Battery starts to fail
If this takes place whilst the data is being stored in the EEPROM, the system does not manage to guarantee this information and the data relating to the "self-learning not carried out" state is memorized.
PROBLEMS DURING THE SELF-LEARNING PROCEDURE
If the procedure cannot be completed properly due to a problem with one or more of the actuators, the system exits the procedure without modifying the data memorized previously in the EEPROM and memorizes the information relating to the "self-learning not carried out" state. |
Funtazista Италомафиози
Возраст: 43 Знак зодиака:  Зарегистрирован: 06.07.2007 Сообщения: 1000 Откуда: Киев, Академгородок
Авто: Fiat GP 1.4 , DUALOGIC
Andrii Италофан
Добавлено: Вт Апр 30, 2013 09:38 Заголовок сообщения: |
даFuntazista |
logos231 Amico
Возраст: 48 Знак зодиака:  Зарегистрирован: 01.03.2012 Сообщения: 27 Откуда: Феодосия
Добавлено: Чт Сен 26, 2013 16:39 Заголовок сообщения: |
Короче, лето кончилось. пришлось ехать на сто разбираться с проблемой. Оказалась банальщина, шестеренка заслонки отламалась. Она расположена на печке. В связи с этим пара вопросов, можно ли ее отдельно заказать или надо ломать голову как ее приделать, и чтоб снять печку надо всю торпеду снимать? Спасибо за участие |
XoLoDoK Amico
Возраст: 34 Знак зодиака:  Зарегистрирован: 08.05.2014 Сообщения: 8 Откуда: Россия
Авто: Фиат гранд пунто
Добавлено: Чт Май 08, 2014 15:02 Заголовок сообщения: |
logos231 у меня также моторчик провернул шестеренку заслонки и отломил моторчик почемуто прокручивается!!! как ты решил проблему!!!! |
