Потрібна ваша допомога. Хочеться щоб не сильно бумкало біль чистого звуку.
Що вибрати з цього
Акустика HERTZ DSK 165.3 CAR AUDIO 6.5" COMPONENT SPEAKERS MIDS TWEETERS CROSSOVERS
Power Handling:
80W RMS
160W Peak
4-Ohm Impedance
Sensitivity: 93dB SPL
Hi Pass Crossover
Crossover Cut-Off: 3.5 kHx at 12dB Oct
Mounting Depth: 2.5"
KICKER 40CSS654 CAR AUDIO 6.5" CS SERIES COMPONENT SPEAKER SYSTEM SET 6-1 /2"
6-1/2" CS Series Car Component Speaker System
Peak: 300 watts
RMS: 100 watts
Impedance: 4 Ohms
Sensitivity: 90 dB
Frecuency Response: 35-21,000 Hz
Infinity 6500CX 6.5" 540W 2 Way Reference X Series Car Audio Component System
Power Handling:
Peak: 540 watts per pair / 270 watts each
RMS: 180 watts per pair / 90 watts each
Polypropylene cone material
Plus One woofer cone technology maximizes cone surface area
Butyl Rubber speaker surround
1" edge-driven Textile Dome tweeter
Adjustable 0 or +3dB tweeter level attenuation
High-temperature voice coil design
Ferrite magnet motor structure is vented for fast cooling
3 ohms impedance works with all amps rated for 4-ohm operation
True 4 ohm technology incorporates speaker impedance with factory speaker wire impedance for maximum power
Includes external crossover for to filter harmful frequencies
Frequency response: 53-21,000 Hz
Top-mount depth: 2-1/16"
Sensitivity: 93dB
Weight: 8 LBS
INFINITY PERFECT6.1 PERFECT 6.5-INCH 6-1/2" CAR AUDIO COMPONENT SYSTEM SPEAKERS
Kappa Perfect 6.1 - 6-1/2" Component System
Model: PERFECT6.1 Kappa Series
Peak: 800 watts per system / 400 watts each
RMS: 200 watts per system / 100 watts each
Impedance: 3 Ohms
Frequency Response: 75 - 23000 Hz
Sensitivity: 90 dB
Deep-anodized aluminum woofer cone for incredible detail and accuracy
1" edge-driven aluminum tweeter with rubber surround
Mount Tweeter Mounting System: for Angled Flush or Surface Mounting
Top Mount Depth: 2-3/4
Cutout Dimensions: 5-1/16
JBL P660C POWER 6.5" 270W COMPONENT SPEAKERS TEXTILE DOME TWEETERS CROSSOVERS
Speaker Size 6-1/2
Design 2-way Component System
Tweeter Design Dome
Tweeter Composition Textile
Woofer Composition Honeycomb Laminate (HCL)
Woofer Surround Rubber
Peak Power Handling 270 watts
RMS Power Handling 90 watts
Sensitivity 94 dB
Frequency Response 45 - 23000 Hz
Impedance (per voice coil)
2 ohms
Top Mount Depth 2-1/4
Сабвуфер
Pioneer TS-SWX2502 Car 10"
10" Single 4 ohm TS Series Shallow Mount Subwoofer
Power Handling:
Peak: 1,200 watts
RMS: 400 watts
Impedance: 4
Reinforced MICA injection molded resin cone
Elastic polymer surround
Frequency Response: 20-125 Hz
Sensitivity: 93dB
36 oz. ferrite magnet motor structure
1-year Dynamic AutoSound Warranty
JBL GT5-1202BR Single 1100W 12
Subwoofer Features:
12" Single GT Series Subwoofer
Power Handling:
Peak: 1100 watts
RMS: 275 watts
Recommended power range: 100 - 300 watts RMS @ 2 ohms
Nominal Impedance: 2 ohms
Polypropylene cone woofer
Rubber surround
Rubber coated tinsel leads
Vented motor structure
Dual-stacked, oversized magnets
Sensitivity: 90 dB
Authorized Internet Dealer
1-year Manufacturer's warranty (subwoofer only)
Enclosure Specifications:
JBL Tuned Slipstream Ported Enclosure
Designed specifically for the JBL GT5-12 subwoofer
Tuned to an optimal 45-150 frequency response
Recommended power handling: 100-275 watts RMS
Wired internally for a final impedance of 2 ohms
Covered in black carpet for looks and durability
Sturdy grill protects the subwoofer from unnecessary damage
Gold plated terminals or excellent connectivity
Banana clip ready
Made from durable 3/4" MDF (Medium Density Fiberboard
Dimensions: 10-15/16"D1 x 14"D2 x 22-5/8"W x 14-9/16"H
Kicker 40TCWS104 CompS 10” 4 Ohm Car Subwoofer in Shallow Sub Enclosure TCompS10
Kicker 40TCWS104 Ported truck enclosure with one 4-ohm 10" CompS subwoofer
600 watts peak power output
300 watts RMS output
3/4" Medium-density fiberboard construction covered with carpet
Impedance: 4-ohms
Frequency response: 30-500 Hz
Sensitivity: 93.8 dB
Internal bracing for additional strength and support
Ribbed Surround
Spiralead Tinsel Leads
Steel Basket with Vented Pole Piece
Large-diameter spider
Ты представил на выбор довольно разные ценовые категории, а усь вообще от и до по цене.
Нужно сузить поиск.
А вообще глобально автозвук очень сложный процесс, я прочитал не одну статью.
Ссыль тебе в помощь http://autozvuk.org/forum2/index.php _________________ Fiat Punto GT 1.4 Turbo-монстрик
ZFA17600000002578
Нужно сузить поиск.
Бюджет 300-500 $ . Якщо я правильно зрозумів то сабвуфер треба брати пасивний так як буде підсилювач 4-ох канальний.
Припустим такий варіант.
Фронт
компонентий 150-200
саб - 100-130
підсилювач на решту.
Чи краще твитера брати окремо і мідбаси?
JBL (kicker) - твітера і мідбаси (можливо ішші компанії)
Саб - JBL Focal kicker
ну і підсилювач.
Щоб багажник розривало не потрібно. Хочеться чистої музики.
Такс, значит исходим из того что с магнитолой все в порядке.
Компоненты Infinity REF6500CX - 165$ (они отличные, хотя звучание слишком характерное, больше подходят для альтернативы, и электроники), если хочется больше инструментала и вокала, то лучше рассмотреть Morel Tempo 6 - 190$
Сабвуфер например Alpine sbg-1244br - 140$ (альтернатив в этой цене особо то и нет)
Ну и усилитель мощная 4 каналка: так чтоб вкусить что такое мощность, то нужно смотреть на Carpower POWER 4/400 - 210$
Если сильно трясти не нужно, то комфортную громкость обеспечит и что-то типа Focal Auditor r-4280 - 129$
Ну и конечно не забываем про проводку для коммутации этого всего без фанатизма 35$
Итак например комплект по максимуму:
Проводка 35$
итого: 575$ - 10% для форумчан = 518$
Все есть в наличии, новое с гарантией и тд. _________________ Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
(о44) 384-22-82, (о63) 384-10-10
саб Rockford Fosgate P3SD4-8
акустика JBL GTO 609C
FOCAL 165A1
підсилювач
ROCKFORD FOSGATE R600-4D
ROCKFORD FOSGATE R400-4D
Як буде звучати такий підбір?
я так зроззмів буде дорожче але чи якісніше?
саб Rockford Fosgate P3SD4-8 - это сабвуфер для установки фриэйр, в полку там или куда еще, кроме этого выдающихся характеристик он за собой не тянет, тем более в Украину его еще не поставляли.
Конечно изготовить короб на заказ будет явно поинтереснее, но выходит за бюджет.
Динамиков же отдельно есть множество классных, тот же rockford, hertz, focal, morel все +\- 100$
акустика JBL GTO 609C - это акустика слабее чем инфинити, так как сам брэнд Infinity задуман как престиж брэнд Harman Group (которые и выпускают JBL) это как тойота и лексус. Сначала идет jbl gt, jbl gto потом уже infinity reference и infinity kappa.
FOCAL 165A1 - ниче вариант, но опять же это нижняя линейка фокал и он проигрывает по всем параметрам как morel так и infinity. Focal стоит рассматривать от линейки перфоманс - PS 165 или вообще шикарная акустика - PS 165 FX - 330 $ (или если есть процессорная магнитола, то вполне можно обмануть судьбу и взять PS 165 F за 267$, выкинув кроссовер. Хуже не будет, проверено.)
підсилювач
ROCKFORD FOSGATE R600-4D - в Украину пока не заезжал
ROCKFORD FOSGATE R400-4D - есть, правда по мощности не супер
Если есть возможность выйти за бюджет: то я б по рекомендовал Ground Zero GZTA 4125X - 247$ - реально монстр
Идеальный вариант за вменяемую сумму:
Focal PS 165 FX - 330 $ (или если есть процессорная магнитола, то PS 165 F за 267$)
саб Hertz ES 250 - 104$ или Morel Primo 104 - 179$
+ кастомный короб 40-50$
+ проводка 50-100$ (так как техника стала более серьезной)
ОООчень желательно процессорную голову чтоб подружить это все вместе максимально эффективно
и конечно шумовиброизоляция, как минимум дверей. Хотя последний раз когда я включал этот усилок, то шумка явно нужна была половине кузова)) _________________ Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
Если уже берешь 4х каналку, то лучше любой Саб, чем никакого. Хоть какой-то Мистери вонючий за 50$ и то будет в разы лучше чем без саба вообще. _________________ Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
Значить на мій бюджет оптимальним варіантом буде
акустика до 60вт
саб до 200 Вт
підсилювач 400 вт
+ проводка.
При выборе акустики не стоит руководствоваться мощностью, ее в большинстве случаев штопают от фонаря.
Надо в первую очередь понять задачу. Если хочется просто громкой и плотной музыки, то достаточно взять реально любую четырехканалку, бюджетный саб и комплект на фронт, хотяб за 100$.
В итоге все вложится где-то в 350$.
Если хочется сделать реально что-то стоящее(так чтоб не стыдно показать знатоку), то без 800$ можно не соваться.
Золотую середину я предлагал в первом же посте, если взять все по минимуму:
Вы не можете начинать темы Вы не можете отвечать на сообщения Вы не можете редактировать свои сообщения Вы не можете удалять свои сообщения Вы не можете голосовать в опросах Вы не можете присоединять файлы в этом форуме Вы не можете скачивать файлы в этом форуме
