Допоможіть підібрати акустику.
Начать новую тему   Ответить на тему    Список форумов Український клуб фанів FIAT / CLUB UCRAINO TIFOSO DELLA FIAT -> Автозвук
dovgyi
Авто: Fiat Doblo
СообщениеДобавлено: Пт Фев 19, 2016 00:48    Заголовок сообщения: Допоможіть підібрати акустику. Ответить с цитатой
Потрібна ваша допомога. Хочеться щоб не сильно бумкало біль чистого звуку.
Що вибрати з цього
Акустика
HERTZ DSK 165.3 CAR AUDIO 6.5" COMPONENT SPEAKERS MIDS TWEETERS CROSSOVERS
Power Handling:
80W RMS
160W Peak
4-Ohm Impedance
Sensitivity: 93dB SPL
Hi Pass Crossover
Crossover Cut-Off: 3.5 kHx at 12dB Oct
Mounting Depth: 2.5"
KICKER 40CSS654 CAR AUDIO 6.5" CS SERIES COMPONENT SPEAKER SYSTEM SET 6-1 /2"
6-1/2" CS Series Car Component Speaker System
Peak: 300 watts
RMS: 100 watts
Impedance: 4 Ohms
Sensitivity: 90 dB
Frecuency Response: 35-21,000 Hz
Infinity 6500CX 6.5" 540W 2 Way Reference X Series Car Audio Component System
Power Handling:
Peak: 540 watts per pair / 270 watts each
RMS: 180 watts per pair / 90 watts each
Polypropylene cone material
Plus One woofer cone technology maximizes cone surface area
Butyl Rubber speaker surround
1" edge-driven Textile Dome tweeter
Adjustable 0 or +3dB tweeter level attenuation
High-temperature voice coil design
Ferrite magnet motor structure is vented for fast cooling
3 ohms impedance works with all amps rated for 4-ohm operation
True 4 ohm technology incorporates speaker impedance with factory speaker wire impedance for maximum power
Includes external crossover for to filter harmful frequencies
Frequency response: 53-21,000 Hz
Top-mount depth: 2-1/16"
Sensitivity: 93dB
Weight: 8 LBS
INFINITY PERFECT6.1 PERFECT 6.5-INCH 6-1/2" CAR AUDIO COMPONENT SYSTEM SPEAKERS
Kappa Perfect 6.1 - 6-1/2" Component System
Model: PERFECT6.1 Kappa Series
Peak: 800 watts per system / 400 watts each
RMS: 200 watts per system / 100 watts each
Impedance: 3 Ohms
Frequency Response: 75 - 23000 Hz
Sensitivity: 90 dB
Deep-anodized aluminum woofer cone for incredible detail and accuracy
1" edge-driven aluminum tweeter with rubber surround
Mount Tweeter Mounting System: for Angled Flush or Surface Mounting
Top Mount Depth: 2-3/4
Cutout Dimensions: 5-1/16
JBL P660C POWER 6.5" 270W COMPONENT SPEAKERS TEXTILE DOME TWEETERS CROSSOVERS
Speaker Size 6-1/2
Design 2-way Component System
Tweeter Design Dome
Tweeter Composition Textile
Woofer Composition Honeycomb Laminate (HCL)
Woofer Surround Rubber
Peak Power Handling 270 watts
RMS Power Handling 90 watts
Sensitivity 94 dB
Frequency Response 45 - 23000 Hz
Impedance (per voice coil)
2 ohms
Top Mount Depth 2-1/4
Сабвуфер
Pioneer TS-SWX2502 Car 10"
10" Single 4 ohm TS Series Shallow Mount Subwoofer
Power Handling:
Peak: 1,200 watts
RMS: 400 watts
Impedance: 4
Reinforced MICA injection molded resin cone
Elastic polymer surround
Frequency Response: 20-125 Hz
Sensitivity: 93dB
36 oz. ferrite magnet motor structure
1-year Dynamic AutoSound Warranty
JBL GT5-1202BR Single 1100W 12
Subwoofer Features:
12" Single GT Series Subwoofer
Power Handling:
Peak: 1100 watts
RMS: 275 watts
Recommended power range: 100 - 300 watts RMS @ 2 ohms
Nominal Impedance: 2 ohms
Polypropylene cone woofer
Rubber surround
Rubber coated tinsel leads
Vented motor structure
Dual-stacked, oversized magnets
Sensitivity: 90 dB
Authorized Internet Dealer
1-year Manufacturer's warranty (subwoofer only)
Enclosure Specifications:
JBL Tuned Slipstream Ported Enclosure
Designed specifically for the JBL GT5-12 subwoofer
Tuned to an optimal 45-150 frequency response
Recommended power handling: 100-275 watts RMS
Wired internally for a final impedance of 2 ohms
Covered in black carpet for looks and durability
Sturdy grill protects the subwoofer from unnecessary damage
Gold plated terminals or excellent connectivity
Banana clip ready
Made from durable 3/4" MDF (Medium Density Fiberboard
Dimensions: 10-15/16"D1 x 14"D2 x 22-5/8"W x 14-9/16"H
Kicker 40TCWS104 CompS 10” 4 Ohm Car Subwoofer in Shallow Sub Enclosure TCompS10
Kicker 40TCWS104 Ported truck enclosure with one 4-ohm 10" CompS subwoofer
600 watts peak power output
300 watts RMS output
3/4" Medium-density fiberboard construction covered with carpet
Impedance: 4-ohms
Frequency response: 30-500 Hz
Sensitivity: 93.8 dB
Internal bracing for additional strength and support
Ribbed Surround
Spiralead Tinsel Leads
Steel Basket with Vented Pole Piece
Large-diameter spider
Kicker 10TC104 Comp 10” 4-Ohm Car Audio Subwoofer w/ Slim Enclosure TC10-4
Kicker 10TC102 Comp 4-Ohm Car Audio Subwoofer
Peak Power: 300 Watts
RMS Power: 150 Watts
Impedance: 4 Ohms
Woofer Size: 10 inches
World’s best bass value, and ready to drop in a trunk
Ready-made, outrageous KICKER bass
Easy-to-use impedance designated at the terminal cup assembly
Injection-molded, polypropylene cone with bracing eliminates distortion
Tough KICKER wood enclosure
Dense gray carpeting
Monogrammed, carbon-fiber front baffle
Optimized Polyfoam Ribbed Surround
Extremely rigid cone, along with 360 degree back bracing eliminates distortion
Double stitched surround for enhanced durability
Tinsel leads woven into the spider with Kicker's Spiralead technology
Single high-temperature voice coil
Height ( in,cm): 13-3/4 , 38.4
Width ( in,cm): 21-3/4 , 55.1
Depth ( in,cm): 4 3/4 , 12
Second Depth ( in,cm): 7-11/16 , 19.5
SBR-S8-4 ALPINE 8" SUB SINGLE PORTED ENCLOSURE LOADED WITH TYPE-R SUBWOOFER BOX
ported enclosure with one 8" Type-R woofer
3/8" medium-density fiberboard construction (3/4" MDF front baffle)
4-ohm total impedance
recommended power: 150-350 watts RMS (1,000 watts peak power)
frequency response: 30-200 Hz
19-1/4"W x 11-3/8"H x 6-5/8""D
12" Woofer Subwoofer Speaker 1800W BASS TUBE Car Audio Stereo Sound Sub NBT120
Premium 12" Passive (Non-amplified) Bass Tube
Rear Vent for Extended Bass Response
Heavy-Duty Black Carpeted Enclosure
Advanced Bass Reflex Design
Frequency Response: 33Hz to 800Hz
High Quality Gold Plated Connectors
Power Handling Max: 1800W
Power Handling RMS: 300W
Sensitivity: 87dB +/- 3dB
Impedance: 4 Ohms
Magnet Mass: 66.8OZ
Dimensions: 26" Length x 13.19" Diameter
Weight: 21lbs
One Year Warranty
Mounting Tie Down Straps Included
Підсилювач 4-ох канальний
що вибрати тут
http://www.ebay.com/sch/Amplifiers-/38638/i.html?_dcat=38638&Channels=4&rt=nc&_trksid=p2045573.m1684
яка путужність підсилювача має бути?
StarsOn
Клубный казначей
Клубный казначей
Авто: Fiat Punto GT 1.4 Turbo-монстрик, Fiat Uno 1.0 Бедняга, Citroen GP Кот-Бегемот
СообщениеДобавлено: Пт Фев 19, 2016 10:07    Заголовок сообщения: Ответить с цитатой
Ты представил на выбор довольно разные ценовые категории, а усь вообще от и до по цене.
Нужно сузить поиск.
А вообще глобально автозвук очень сложный процесс, я прочитал не одну статью.
Ссыль тебе в помощь http://autozvuk.org/forum2/index.php
ZFA17600000002578
Brend
Авто: Fiat Tipo 1.4 -> Alfa Romeo 156 1.8TS -> Honda Civic VI Coupe 1.6 Turbo -> Honda Accord 5 Coupe 2.2
СообщениеДобавлено: Пт Фев 19, 2016 15:04    Заголовок сообщения: Ответить с цитатой
dovgyi
Сформируй пожелания и бюджет мероприятия точнее, помогу с подбором.
Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
(о44) 384-22-82, (о63) 384-10-10
dovgyi
Авто: Fiat Doblo
СообщениеДобавлено: Пт Фев 19, 2016 16:04    Заголовок сообщения: Ответить с цитатой
Бюджет 300-500 $ . Якщо я правильно зрозумів то сабвуфер треба брати пасивний так як буде підсилювач 4-ох канальний.
Припустим такий варіант.
Фронт
компонентий 150-200
саб - 100-130
підсилювач на решту.
Чи краще твитера брати окремо і мідбаси?
JBL (kicker) - твітера і мідбаси (можливо ішші компанії)
Саб - JBL Focal kicker
ну і підсилювач.
Щоб багажник розривало не потрібно. Хочеться чистої музики.
dovgyi
Авто: Fiat Doblo
СообщениеДобавлено: Пт Фев 19, 2016 16:11    Заголовок сообщения: Ответить с цитатой
Нужно сузить поиск.
Дякую буду дивитись.
Brend
СообщениеДобавлено: Пт Фев 19, 2016 17:15    Заголовок сообщения: Ответить с цитатой
Фронт
компонентий 150-200
саб - 100-130
ну і підсилювач.
Такс, значит исходим из того что с магнитолой все в порядке.
Компоненты Infinity REF6500CX - 165$ (они отличные, хотя звучание слишком характерное, больше подходят для альтернативы, и электроники), если хочется больше инструментала и вокала, то лучше рассмотреть Morel Tempo 6 - 190$
Сабвуфер например Alpine sbg-1244br - 140$ (альтернатив в этой цене особо то и нет)
Ну и усилитель мощная 4 каналка: так чтоб вкусить что такое мощность, то нужно смотреть на Carpower POWER 4/400 - 210$
Если сильно трясти не нужно, то комфортную громкость обеспечит и что-то типа Focal Auditor r-4280 - 129$
Ну и конечно не забываем про проводку для коммутации этого всего без фанатизма 35$
Итак например комплект по максимуму:
Проводка 35$
итого: 575$ - 10% для форумчан = 518$
Все есть в наличии, новое с гарантией и тд.
dovgyi
Авто: Fiat Doblo
СообщениеДобавлено: Пт Фев 19, 2016 17:45    Заголовок сообщения: Ответить с цитатой
Варіант я так зрозумів провірений.
А якщо підбирати щось з цих фірм
саб
Alpine
JL Audio
Kenwood
Kicker
Lanzar
Memphis
Rockford Fosgate
JBL
акустика
CDT Audio
Focal
Kicker
MB Quart
Rockford Fosgate
JBL
підсилювач
Blaupunkt
Hifonics
Kicker
MB Quart
Pioneer
Planet Audio
Power Acoustik
Rockford Fosgate
Soundstream
чи є такі в списку які себе погано зарекомендували і в їхню сторону краще не дивитись.
На рахуно Сабвуфера чи не буде краще взяти відкритий і під нього зробити коробку?
dovgyi
Авто: Fiat Doblo
СообщениеДобавлено: Пт Фев 19, 2016 18:39    Заголовок сообщения: Ответить с цитатой
А якщо
саб Rockford Fosgate P3SD4-8
акустика JBL GTO 609C
FOCAL 165A1
підсилювач
ROCKFORD FOSGATE R600-4D
ROCKFORD FOSGATE R400-4D
Як буде звучати такий підбір?
я так зроззмів буде дорожче але чи якісніше?
Brend
СообщениеДобавлено: Пт Фев 19, 2016 23:50    Заголовок сообщения: Ответить с цитатой
dovgyi писал(а):
А якщо
FOCAL 165A1
підсилювач
саб Rockford Fosgate P3SD4-8 - это сабвуфер для установки фриэйр, в полку там или куда еще, кроме этого выдающихся характеристик он за собой не тянет, тем более в Украину его еще не поставляли.
Конечно изготовить короб на заказ будет явно поинтереснее, но выходит за бюджет.
Динамиков же отдельно есть множество классных, тот же rockford, hertz, focal, morel все +\- 100$
акустика JBL GTO 609C - это акустика слабее чем инфинити, так как сам брэнд Infinity задуман как престиж брэнд Harman Group (которые и выпускают JBL) это как тойота и лексус. Сначала идет jbl gt, jbl gto потом уже infinity reference и infinity kappa.
FOCAL 165A1 - ниче вариант, но опять же это нижняя линейка фокал и он проигрывает по всем параметрам как morel так и infinity. Focal стоит рассматривать от линейки перфоманс - PS 165 или вообще шикарная акустика - PS 165 FX - 330 $ (или если есть процессорная магнитола, то вполне можно обмануть судьбу и взять PS 165 F за 267$, выкинув кроссовер. Хуже не будет, проверено.)
підсилювач
ROCKFORD FOSGATE R600-4D - в Украину пока не заезжал
ROCKFORD FOSGATE R400-4D - есть, правда по мощности не супер
Если есть возможность выйти за бюджет: то я б по рекомендовал Ground Zero GZTA 4125X - 247$ - реально монстр
Идеальный вариант за вменяемую сумму:
Focal PS 165 FX - 330 $ (или если есть процессорная магнитола, то PS 165 F за 267$)
саб Hertz ES 250 - 104$ или Morel Primo 104 - 179$
+ кастомный короб 40-50$
+ проводка 50-100$ (так как техника стала более серьезной)
ОООчень желательно процессорную голову чтоб подружить это все вместе максимально эффективно
и конечно шумовиброизоляция, как минимум дверей. Хотя последний раз когда я включал этот усилок, то шумка явно нужна была половине кузова))
dovgyi
Авто: Fiat Doblo
СообщениеДобавлено: Сб Фев 20, 2016 21:11    Заголовок сообщения: Ответить с цитатой
А якщо вибрати варіант без сабвуфера.
з 4 канальним підсилювачем. (на майбутне)
Акустику на зад в полки або по бакам.
Чи можливий варіант просто з підсилювачем і хорошою фронтовою акустикою?
Brend
СообщениеДобавлено: Сб Фев 20, 2016 22:28    Заголовок сообщения: Ответить с цитатой
Если уже берешь 4х каналку, то лучше любой Саб, чем никакого. Хоть какой-то Мистери вонючий за 50$ и то будет в разы лучше чем без саба вообще.
dovgyi
Авто: Fiat Doblo
СообщениеДобавлено: Вс Фев 21, 2016 16:02    Заголовок сообщения: Ответить с цитатой
Значить на мій бюджет оптимальним варіантом буде
акустика до 60вт
саб до 200 Вт
підсилювач 400 вт
+ проводка.
Brend
СообщениеДобавлено: Вс Фев 21, 2016 16:19    Заголовок сообщения: Ответить с цитатой
акустика до 60вт
саб до 200 Вт
підсилювач 400 вт
+ проводка.
При выборе акустики не стоит руководствоваться мощностью, ее в большинстве случаев штопают от фонаря.
Надо в первую очередь понять задачу. Если хочется просто громкой и плотной музыки, то достаточно взять реально любую четырехканалку, бюджетный саб и комплект на фронт, хотяб за 100$.
В итоге все вложится где-то в 350$.
Если хочется сделать реально что-то стоящее(так чтоб не стыдно показать знатоку), то без 800$ можно не соваться.
Золотую середину я предлагал в первом же посте, если взять все по минимуму:
Проводка 35$
итого: 469$ - 10% для форумчан = 422$
dovgyi
Авто: Fiat Doblo
СообщениеДобавлено: Вс Фев 21, 2016 16:57    Заголовок сообщения: Ответить с цитатой
Дякую. Мені для себе знатокам не обовязково показувати. )))
dovgyi
Авто: Fiat Doblo
СообщениеДобавлено: Вс Фев 21, 2016 21:45    Заголовок сообщения: Ответить с цитатой
Проводка 35$
А саб безкорпусний який краще? думаю під пасаж. сідушки кинути. місця хватає тільки потрібно плоским зробити буде.
І Infinity REF6500CX замінити на Morel Tempo 6 .
А підсилювач Carpower POWER 4/400 чим кращий за Focal Auditor r-4280
Начать новую тему   Ответить на тему    Список форумов Український клуб фанів FIAT / CLUB UCRAINO TIFOSO DELLA FIAT -> Автозвук Часовой пояс: GMT + 3
Вы не можете скачивать файлы в этом форуме
